Author Topic: Expected quite some noise, but found nearly none.  (Read 1170 times)
Offline eTobeyTopic starter
  • Virtual Features for the SDS800XHD -> My website
    • Virtual feature script
« on: January 11, 2025, 11:34:07 pm »
i have a coil, that i send current through with a half bridge. After the coil i have a shunt resistor, and there i measure the current (green trace in ampere), that swings (seemingly) about 2.6A pk-pk with quite a steep slope. It is the second ringing on the screenshots, that i refer to.
Blue trace:    Gate of HS
Red trace:     Voltage of shunt (0.104Ohm)
Yellow trace:  Measured noise with a 15mm shorted loop.
Green trace:  Ampereof coil
Full bandwith with peakdetect.
The loop was help right on the cable, but there was only 20mVpk noise. I would have expected about 10 times more. Other chips on the PCB generate higher peak noise.
Do i measure a signal that is not there with that amplidtude, or do i have to measure this noise differently?
« Last Edit: January 17, 2025, 01:16:26 pm by eTobey »
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant."(Maxim Gorki)
SDS800X HD bugs/issues/workarounds (Updated 17. Feb. 2025)
Online temperance
Re: Expected quite some noise, but found nearly none.
« Reply #1 on: January 11, 2025, 11:55:21 pm »
The induced voltage depends on the rate of change of current.
« Reply #2 on: January 12, 2025, 11:59:13 am »
227A/us would not be quite a rate of change?
Offline jonpaul
    • IEEE Spectrum
« Reply #3 on: January 12, 2025, 03:02:19 pm »
Ringing due to poor probe technique and bad breadboard setup.
Read about power supply measurements and probe measurements first.
j
The Internet Dinosaur..
passionate about analog electronics since 1950s
The following users thanked this post: pardo-bsso
Offline mtwieg
« Reply #4 on: January 12, 2025, 03:49:04 pm »
Your descriptions of the scope traces don't make much sense:
I'm guessing we see two transitions because of dead time in the half bridge? Is the y scaling right, drive voltage is only around 5V?
So it looks like the current shoots up to >30A (3V/0.1ohm), at which point the trace is off the screen... is that right?
.... what?
So you're measuring current with something else besides the shunt resistor (red trace)? What's the sensitivity of this sensor?
Online temperance
« Reply #5 on: January 12, 2025, 04:04:25 pm »
j
That's not what the question is about? The question is about induced voltage in a loop created by shorting the probe to the tip.
« Reply #6 on: January 12, 2025, 05:28:33 pm »
.... what?
It is the gate on turn on. See the miller plateau. It goes up to 10V after that.
The red trace is a bit missleading, as i have F3 activated (which is of no interest). C2 ( the other red) is not leaving the screen.
Yellow trace is measured with a DIY field probe.
No, there is no other sensor, it is a math function.
« Last Edit: January 12, 2025, 05:33:49 pm by eTobey »
« Reply #7 on: January 12, 2025, 05:31:43 pm »
j
What about you reading my post and looking at my pictures first, before you give an answer? Or dont do drugs or alcohol, since you see things, that  are just not there! There is no breadboard, and the probing technique i would consider not poor.
It is of no use whatsoever, to give answers just from ones guessings, when there are informations, so that one would not need to guess!
« Last Edit: January 12, 2025, 05:37:28 pm by eTobey »
Online temperance
« Reply #8 on: January 13, 2025, 02:33:19 am »
j
I think you have to admit that what you wrote isn't very clear and the picture doesn't show much either. It shows a probe attached to a power resistor and some wires. Where is the DIY field probe? Because that's what you're question is all about.
« Last Edit: January 13, 2025, 02:35:12 am by temperance »
Offline mikerj
« Reply #9 on: January 13, 2025, 08:59:02 am »
j
Calm down, this kind of attitude isn't going to want people to help you.  Why would you think that a wire wound power resistor would be appropriate for measuring rapidly changing currents?
Offline mtwieg
« Reply #10 on: January 13, 2025, 12:59:42 pm »
I highly doubt that whole thing is one miller plateau, unless you intentionally added a ton of Cgd for some reason. Can you show what Vds looks like at the same time?
By C2 you're referring to the pink-ish trace in the third capture? Is that the voltage across the shunt resistor?
I understand using sniffer coils/pickup loops for detecting HF ringing, but it's impossible to make heads or tails of its output without knowing more about it (like what is its self resonant frequency) and exactly how it's positioned.
What is a math function? Of what?
It's hard to say for sure without seeing the larger setup.
« Reply #11 on: January 14, 2025, 06:42:01 am »
Its a wireloop on the tip of a probe, square about 15-20mm. Not worth a picture IMHO.
Because it does conduct current, and it creates a voltage drop without going up in flames. Why would it not be appropriate?
That Millerplateau looks distorted, since the gate current is controlled by the driver (6EDL7141).
Yes its the pinkish trace. Its a mess with these colors...
Yes its the voltage accross the shunt.
Would the selfresonant frequency be so much of a factor, when there are only a few swings, or even on edge?
The wireloop was positioned on the cable in the best way (tested on multiple places) to pick up the most noise/signal.
Its the math function of the scope.
« Last Edit: January 14, 2025, 06:44:02 am by eTobey »
« Reply #12 on: January 15, 2025, 11:19:32 am »
I conducted another test, as the method of current measurement was questioned:
What i found is, that the magnetic field, that is produced by the changing current, induces a bigger voltage on the signal, than the actual voltage that is produced by the current in the shunt itself.
I did it like this:
Used a resistor wire, and measured with a short standart ground spring (pink trace), and did another measure with a longer ground wire (red trace), that had about 2-3 times as much loop area. Those two measures were taken on the same point (pretty close at least) of the resistor wire The second measure had much bigger Vpp values.
Therefore i did not measure to little noise, i just measured too much current.
« Last Edit: January 15, 2025, 11:21:14 am by eTobey »
