Author Topic: Experience with buttons inside potting material ?  (Read 5179 times)
Offline babysitterTopic starter
  • pushing silicon at work
« on: February 13, 2014, 09:06:27 am »
I am thinking about a circuit which shall be completely potted in polyurethane, including a battery, intended for single shot use.
To prevent the need to mix the potting material again every time and lose time before using, I plan to use a soft power switch cast in.
Does anyone have experience with tactile switches cast in a soft potting material? I am thinking about Omron B3F which look somewhat tight to me, hopefully the PU doesn't enter into the inner room which might be prevented by the sealing mass sold for the material right on the switch . To prevent actuation by the (hopefully low) shrinking force, I would buy a high force type.
As potting material I am going for a soft 2-component polyurethane, http://www.peters.de/en/products/casting-compounds/casting-compounds-opaque/254-wepuran-casting-compounds-on-polyurethane-resin-basis-pur/519-vu-4444-31-sb-wb-and-vu-4494-31-sb-wb
My trainee is already putting a few buttons on perfboard which we will pot with a slant angle so the height above the plunger is different, but it will take some time until we get the PU maaterial.
Thanks in advance
Babysitter
I'm not a feature, I'm a bug! ARC DG3HDA
Offline enz
Re: Experience with buttons inside potting material ?
« Reply #1 on: February 13, 2014, 10:09:31 am »
Another idea:
How about a reed switch? Can easily be activated by a magnet after potting.
I used this a couple of times in hermetically sealed products. Workes well, if it fits your application.
Martin
« Reply #2 on: February 13, 2014, 10:21:49 am »
I considered this also, even packing it all up with a magnet for those who use it.
Now I am looking into "snap dishes" which might be sealed from the PU when I fix them to the PCB with some adhesive tape, and also rubber switches.
« Last Edit: February 13, 2014, 10:41:59 am by babysitter »
« Reply #3 on: February 13, 2014, 11:04:23 am »
Problem No. 1, drowning and isolating the contacts, should be took care of: one can buy waterproof tactile switches ! :)
Offline colotron
  • Country: ar
« Reply #4 on: February 13, 2014, 11:19:59 am »
How does it work?. I saw tact switches  >IP65 in Digi-Key:
http://www.digikey.com/product-search/en?pv69=3&pv69=951&pv69=352&pv697=7&pv697=11&pv697=10&FV=fff40011%2Cfff8005e&mnonly=0&newproducts=0&ColumnSort=0&page=1&stock=1&quantity=1&ptm=0&fid=0&pageSize=100
But I initially thought it means that the switches can be assembled automatically because can be washed in the SMT assembly line after soldering.
Does it mean also that can be used safely in outdoor environments exposed to water and moisture?
« Reply #5 on: February 13, 2014, 11:24:14 am »
Those that have a IP rating (see quite at the end of the filter lists, searchable attribute) should be!
Offline lgbeno
« Reply #6 on: February 13, 2014, 01:11:03 pm »
Reed switch sounds like the best idea that I've read on here.  It is just fur testing, why experiment with all of this switch stuff
Offline calexanian
    • Alex-Tronix
« Reply #7 on: February 14, 2014, 06:03:38 am »
I would use a membrane switch with an integral ribbon connector going down into the epoxy.
Charles Alexanian
Alex-Tronix Control Systems
