Just wondering if anyone has any experience with these? Having some problems with a CK1060 switch. For starters the shaft is a bit wobbly. Not exactly a high quality feel, but OK. Problem is that if you wobble it a bit the connection is a bit wobbly too. Connected a DMM and the resistance goes from a few tenths of an Ohm (so dead short pretty much) to a few hundred killo Ohms. Which, you know, is a bit much for a switch.
Opened the switch up and there was no sign of wear, burn-in, mechanical failure or whatever.
So, this has me scratching my head a bit. Any ideas?
