I'd support the direction of what
sandalcandal says above although I'd go a little further.
I've been running a leadacid setup in a van for the past 4 years and recently became aware of LiFEPO4 as an alternative. After spending a little time looking into it, I figured it was worth a punt. Now, after a few weeks hands-on experimenting, I'm convinced it's a sea-change technology.
Firstly, energy density: this is not 'a couple of times' better, It's more like 4 times. I have 3 x 120ah AGM, so in theory, 50% of rated leadacid capacity being usable = 180ah.
The LiFePO4 cells I just got, are rated 280ah, although I've measured them to hold 300ah using recommended BMS settings. Setting BMS parameters ultra conservatively, I've still got 290ah.
These cells together are smaller than just one of my leadacid units and yet deliver 1.6 x the total capacity. I make that,
4.8 x energy density in practical terms. (I know it's less in theoretical chemical terms)
Secondly Cost: I wanted to get the cells I have quickly so bought from a source warehoused in Poland (hence already inside the EU) and they arrived after 8 days. They cost a little over £600. The BMS was another £120. Compare that to the £300 I paid for the leadacid units, multiplied by the capacity increase £300 x 1.6 = £480. OK, so it looks like an initial cost of 1.5 x lead acid. So we'll be talking about the life cycle benefits to justify it however... if I were to buy the same cells from China (both sources are Chinese, the first warehouses stock in Poland), I'll have to wait 6-8 weeks for delivery but the cost saving is huge: eg
These are just £364 (I have an order from there in transit at the moment). So with the same BMS, that's a total of £484, or simply, the
same cost as leadacid.
Thirdly performance: the general guide is that leadacid should be charged at about 0.1C while LiFEPO4 can be charged at 1C. Similarly, this is the max discharge rate at which they remain efficient.
So pulling 16A from a 100AH leadacid is already beyond its comfort zone (you'll be losing more than you're using), while pulling 5 x that from LiFePO4 is still in it's happy place. As I say, the capacity of my cells is rated 280ah. I'm charging them at >100A and only seeing
very slight heating of the cells. Gotta make sure those busbars are screwed down tight though!!
I can draw 100A from the LifePO4 for an hour and use 100AH from the capacity.
I wouldn't be able to draw 100A from my leadacid set for more than about 20-30 mins before it needed 'a rest'. I'd be surprised if I got as much as 45 mins out of it in total at that discharge rate.
Fourthly, Life Cycle: Typical life cycle...
leadacid = 4-700 cycles
LiFePO4 = 2-4000 cycles
'nuff said.
Finally safety v convenience: Lithium batteries have a rep for bursting into flames, exploding etc. The number of times, I've mentioned my 'experiments' to people and had a response like, "better invest in a decent fire extinguisher". But 'those' lithium batteries are not LiFePO4. Some of them have higher energy density, yes, but are less stable chemistries and hence come with associated risks. LiFePO4 has the perfect balance to be the game-changer (IMHO) because of it's massively increased energy density while being no more volatile than Leadacid. The limits are more strict though so while more factors tend to diminish the performance and life cycle of leadacid, exceeding the ultimate boundaries of LiFePO4 is more likely to kill the cell entirely (hence using a BMS to look after it).
In summary: the balance has shifted - LiFePO4 is just so much better - I'm done with leadacid
