Author Topic: How to check stability/integrity of voltage reference IC?  (Read 920 times)
Offline Red_MicroTopic starter
« on: January 05, 2021, 10:17:08 pm »
I'm using TL431 shunt regulator as the voltage reference of 2.5V for an ADC. If I don't add a cap at the output, this introduces non-linearities in the ADC measurements. When I add a 10uF cap, the reference becomes more stable reducing accuracy errors in ADC. My question is how I can measure or see this behavior with let's say an scope? How can I see this instability of the regulator to understand how it changes when sampling?
Offline bob91343
Re: How to check stability/integrity of voltage reference IC?
« Reply #1 on: January 05, 2021, 10:40:31 pm »
You could build two of them and use a differential probe.
