Electronics => Projects, Designs, and Technical Stuff => Topic started by: SArepairman on August 31, 2014, 07:30:44 pm
Title: explain to me the switched cap frequency controlled gain amplifier (ltc6943)
Post by: SArepairman on August 31, 2014, 07:30:44 pm
(http://s16.postimg.org/yss493r9x/dsfsdfsdfsdf.png)
I get that the switch + capacitor works as a simulated resistor where R = 1/Cs*Fs
So I see there he has 1/(0.0000000001*1000) and 1/(0.00000001*1000) (10:1 clock ratio ) =
10 meg to 10K = gain of 1000
I built this circuit up, though I did not have the same parts on hand, so I used a 1uF and a 10nF
1/(0.00000001*1000) = 100k
1/(0.000001*10000) = 100
So the simulated resistances are alot smaller but the ratio is the same.
I used a 10nF integrator capacitor (just like the app note) and TTL clocks using two function generators (1k and 10k Hz).
I am using a LT1677 op amp with this circuit
I also am using the non inverting form of the circuit (swap pins 7A and 6A (datasheet mentions 8A incorrectly, but I cross checked with the LTC1043 datasheet which has it right).
However, this circuit won't work. It just slowly counts up to the + supply rail, the frequency adjust stage does not matter and if I disconnect the 1KHz clock it outputs close to zero, if I connect the 1KHz clock it slowly moves up to + rail on the output.
Why did the original circuit use such high resistances and a JFET op-amp? And how about the integration capacitor ?
*I used all polypropylene capacitors
Title: Re: explain to me the switched cap frequency controlled gain amplifier (ltc6943)
Post by: SArepairman on September 01, 2014, 01:23:50 am
should perhaps pin 12 and 11 be switched on the second LT6943?
I don't really understand the pin switching thing...
My first LTC6943 does act as a SC resistor, I can measure it with the multimeter when frequency changes (50 ohm - Kohm) . the second one is 10meg w/ 1KHz signal, and the resistance does not change with frequency, but it goes down to 1Meg without a square wave....
I also replaced the 2nd LTC6943, I know its not a bad chip. I checked the wiring. Should both of the LT6943 pins (6-7 and 11-12) be inverted? Right now I have 6-7 (chip 1) inverted and 11 12 ( chip 2 ) like in the diagram
THE RESISTance measurement is directional though, like 80 ohms one way and 600 ohms the other way (on the first simulated resistor).
does this make sense? I guess the op amp could be effecting stuff, but it does change at least..
Post by: SArepairman on September 01, 2014, 03:25:45 am
oh, the 10megs was the input impedance of my multimeter connected to the circuit.
The first stage goes from .5-10k, the second stage is high impedance
*opamp removed during these tests
Post by: Andreas on September 01, 2014, 04:32:34 am
you forget that the switch resistance is around 1000 Ohms (divided by duty cycle 0.5).
So in your case you cannot ignore this resistance.
With best regards
Andreas
Post by: SArepairman on September 01, 2014, 05:06:19 am
With best regards
Andreas
switch resistance is 300ohms in data sheet, but I see what you mean. But I should still be getting something right?
measuring the SC actually, gives me a range of 800-1000 on the first one.. order of magnitude more reverse polarity. I guessing using a ohm meter on these circuits is not the best idea.
why won't it work at all?
Post by: Andreas on September 01, 2014, 06:01:21 am
perhaps your clock does not have full amplitude (-5V to +5V)
with best regards
Andreas
Post by: SArepairman on September 01, 2014, 06:05:29 am
whaaaa? this needs a -/+ clock? It says CMOS is fine.
where did you get this idea from?
MOTHER FUCKER I WISH THIS WAS IN THE DATASHEET. this thing has been plaguing me all day.... now to solder in a mid air comparator to translate the 0-5v signal with a -5v/5V signal....
My circuit board is alllllll fucked up from too much probing/solder probe wires (home made, many traces need to be replaced with bodge) but it seems now that it works somewhat as described with just the ohm meter.  |O |O |O |O |O |O |O |O |O |O |O |O |O |O |O |O |O |O |O
it seems that my nicely made board is going to have a bunch of unplanned additions...
Post by: Andreas on September 01, 2014, 06:35:52 am
Its on page 4 in the picture at the bottom of the side:
The clock has to be with a amplitude of V- to V+.
Edit: the LTC has no ground pin. So it should be clear that his world is referenced by the V- pin.
With best regards
Andreas
Post by: SArepairman on September 01, 2014, 06:59:38 am
With best regards
Andreas
 |O
at least its over
