Hi dear community!
I have an electric scooter (xiaomi mi 365), and i would like to extend it's range. I thought of external e-bike batteries,
because they have a case and a charger, so i could just switch between the original and the external battery when needed.
The only problem i have is that i can't seem to find a pack that has a correct datasheet, from which i would be able to know if it can handle reverse current on the discharge port. Because my scooter does regenerative braking, and it would supply current backwards on the discharge port when i brake.
So can you please advise me what to do, how to solve this?
I would like to solve this the easiest way possible.
(I know of solutions that are common, e.g. firmware patching, or just putting the battery paralell, but i think they are nasty, and would like to avoid them.)
Thank you!
