Hi all,
So I've been designing a rechargeable portable cell phone charger (or powerbank or something) that uses a lithium-ion battery to charge a phone. Here's the schematic:
I got the circuit board made on a milling machine but it's double sided so the homemade vias are not great. Anyway when I connect the battery to the circuit (battery is JP3 in the schematic) LED1 switches on (which is not supposed to happen) and the battery makes a suspicious hissing noise. I haven't left it connected long enough to find out whether it explodes or not.
I just want to confirm that my design is correct or if I've made some error.
VINA, VIN_USB and JP2 in the schematic belong to this USB power multiplexer:
http://www.pololu.com/product/2594/specs. It just switches between USB power from the usb charger and power from the battery.
The step up converter to get 5V out of the battery is this:
http://www.pololu.com/product/798 and the charge controller is a MAX1811. The transistor circuit in the bottom-right corner switches the MAX1811 between high and low charge current.
Thanks in advance
