Author Topic: External power for PCI Express card  (Read 2684 times)
Offline dkaszaTopic starter
« on: December 06, 2013, 03:07:40 am »
Hello everyone,
I just got a board that is too long to fit in my computer (it extends in the wrong direction), but has an ordinary PCI-Express x4 connector. I do not care about the data on this connector. The board has a few FPGAs on it that I intend to reprogram and not use the PCI-Express.
Is there any simple and inexpensive solution to power a PCI-Express card outside a computer?
The board has 4 LTM4600EV devices on the +12V rail, and it has diagnostic LEDs for 5 voltages including +12V, so it is quite possible that the board only needs the +12V and ground pins to be connected, but I could not verify that yet. In that case I could probably just solder leads to these pins and power it from a 12V supply. Still, I would prefer a nicer solution. :)
Thanks!
Online mariush
Offline NiHaoMike
    • Facebook Page
Re: External power for PCI Express card
« Reply #3 on: December 06, 2013, 05:59:48 am »
Or you can get a dead or long obsolete motherboard and take the connector from it.
« Reply #4 on: December 08, 2013, 12:15:34 am »
Thank you all! Just to be safe, I ended up getting an ExpressCard -> PCI-Express adapter. I wanted to get one of these for a long time anyway. Once I get the board to work with this, I will design a less expensive board to power it.
