Author Topic: Isolated Switching DC Load  (Read 2007 times)
Offline dman66Topic starter
« on: November 16, 2017, 10:22:45 pm »
Does anyone have any suggestions for switching an isolated DC load other than using a mechanical relay?
If it was AC (or periodic in some way) I'd use a solid state relay.
The DC load is not very great (under 50v, low current).
Right now I'm using an open collector output - but that is sharing a ground and causing other issues (connecting my board via USB to a PC makes a ground loop, etc.).
Thanks!
Offline viperidae
Re: Isolated Switching DC Load
« Reply #1 on: November 17, 2017, 12:33:42 am »
What about... a solid state relay?
https://www.jaycar.co.nz/medias/sys_master/images/9001015738398/SY4086-dataSheetMain.pdf
That's 30VDC at up to 100A, I'm sure you can find something with a higher voltage if you need to. Or something smaller with a lower current capability.
>4000V isolation
The following users thanked this post: dman66
« Reply #2 on: November 17, 2017, 06:10:19 am »
I should have also mentioned that the DC load doesn't have a fixed polarity.
Most of the solid state relays I've seen that work with DC have a fixed polarity.
Offline nidlaX
« Reply #3 on: November 17, 2017, 08:07:36 am »
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #4 on: November 17, 2017, 09:34:51 am »
Most solid state relays I've seen use two fets, and have no polairty. Search for AC,DC solid state relays.
This one for example: CPC1916.
Offline Zero999
  • 0999
« Reply #5 on: November 17, 2017, 11:38:53 am »
An H-Bridge??
https://en.wikipedia.org/wiki/H_bridge
An h-bridge will not do, since it's used for changing the polarity of the load, not switching an unknown polarity.
What's the load current?
Offline nidlaX
« Reply #6 on: November 17, 2017, 12:08:15 pm »
An H-Bridge??
Thanks.
Offline David Hess
  • DavidH
« Reply #7 on: November 20, 2017, 01:06:07 am »
Solid state relays which use a pair of back-to-back power MOSFETs may be used in DC applications.
Offline floobydust
« Reply #8 on: November 20, 2017, 03:15:21 am »
Consider using a photo-voltaic optocoupler i.e Vishay VOM1271 to drive a couple MOSFETs. Basically you're making a bi-directional SSR, good for AC/DC.
Crydom make DC SSR's but unidirectional (like GN series) but they are pretty expensive. I'm not sure if they have a bi-directional DC offering.
