Author Topic: Voltage regulator that sinks current  (Read 5496 times)
Offline shpavelTopic starter
  • Country: il
« on: May 18, 2017, 06:46:40 am »
Hi
I am lookin some solution for a circuit I am designing. I have 5 volt and I need to create adjustable low voltages in the output. Something below 1.2 volt and above 0.3. The problem is that I need the circuit to be able sink and source current (something in the range of 50 mA). I have looked the web but my knowledge in vr is limited. Where do I start? Can buck step down solution do the work? Can linear vr do it?
Offline Kalvin
  • Embedded SW/HW.
Re: Voltage regulator that sinks current
« Reply #1 on: May 18, 2017, 07:05:39 am »
Op amp.
  • Country: il
« Reply #2 on: May 18, 2017, 07:09:56 am »
The DDR termination ldo are usually not adjustable. The come with constant voltage.
Offline tszaboo
« Reply #3 on: May 18, 2017, 11:11:45 am »
If you take a voltage regulator, and add a resistor on the output, you get a voltage regulator that can source less current than the maximal, it will waste energy continuously, but it can also sink some current. For 0.3V, 50mA you need 5 Ohm. Maximum waste is 1.2V 5 Ohm = 300mW, not too bad.
Or an opamp.
Offline cjm
  • Country: ie
« Reply #4 on: May 20, 2017, 09:37:52 am »
Op amp.
+1
...although sourcing 50mA at 0.3V might be challenging unless you have a negative supply rail for the opamp. Some rail to rail ("RRIO") opamps might just work with just 0v-5V rails - e.g. OPA340, AD8531 or similar.
« Last Edit: May 20, 2017, 10:00:27 am by cjm »
