Author Topic: Fairchild 1F30SD data sheet  (Read 1214 times)
Offline IconicPCBTopic starter
« on: March 07, 2019, 10:53:22 pm »
Looking fo a data sheet or any information at all on a Fairchild 1f30sd.
Tried google... no joy any references to 1f30sd point to distributors of old and obsolete gear with offers of data sheet upon request... however i do not need to purchase materials.. am trying to understand what the component is.
ON semiconductors, the new owners of Fairchild , are as useful  int his regard as the tits on a bull.
Offline amyk
Re: Fairchild 1F30SD data sheet
« Reply #1 on: March 08, 2019, 02:26:08 am »
Could you post a picture?
« Reply #2 on: March 08, 2019, 02:45:13 am »
Certainly... it is the SMD component located between two ferrite core transformers on either side , a blue electrolytic capacitor and axial power resitor in the right half of the image.
Offline amyk
« Reply #3 on: March 08, 2019, 01:02:19 pm »
SMD markings contain date/batch codes too, so you are unlikely to get results by searching for the full mark.
Online SiliconWizard
« Reply #4 on: March 08, 2019, 04:25:51 pm »
Yeah, no datasheet to be found... and yes I doubt any of those brokers will send you a datasheet unless you place an order (and I'm not even sure they really have one for this).
I'm just guessing that it's probably a diode (single or dual). You could try and confirm this with some simple testing.
