I don’t have a data sheet to hand for the controller, it’s an old 82C426 (for driving a 640x200 display). But it’s a standard 4-bit interface, as used by most LCDs prior to LVDS. I haven’t selected a 640x240 display yet. However any old 4-bit (or 8-bit) controller & display using FLM and LP control is representative.
But - knowing how an LCD controller and display works in normal operation - the question asked isn’t likely to be answered by data sheets. As normally you would use a controller that matches the display, or vice-versa, so there are the same number of rows and columns. I’m asking about a scenario outside normal operating parameters.
I’d expect that rows 201 to 240 aren’t being energised. So in theory there is no DC (or AC) across any segments or commons for rows above 200. But is this the case in practice? Does, for example, the effect of the energised planes up to row 200 bleed across to those above 200 over time? This question would apply for any LCD controller using the control signals above with parallel data being used to drive an LCD with more rows that the controller is designed for.
