Author Topic: Recommend general purpose humidity sensor (interface with Raspbery Pi)  (Read 1609 times)
Offline Red Squirrel
This is for my home environmental control system, I just want a couple to play with and also put into use.   I want 0-100% range, decent accuracy like within a few %, 5 volt supply, and i2c or perhaps even 1-wire or other digital signal that will be easy enough to interface with the RPI.
I found this: http://www.digikey.ca/scripts/DkSearch/dksus.dll?Detail&itemSeq=169546055&uq=635635357960147122&CSRT=10012467184009429983
Before I pay that price I just want to see if there's anything else I might be missing.  I'm completely new to RPI interfacing so this will be a learning project.  Basically I'm converting my arduino based home automation system (which uses a server for most of the logic) to use a RPI and it's pins directly.
And on subject of asking for a general purpose part figured I'd ask here too, what is a good general purpose ADC that has decent res, like 16 bit or even 24 or 32?  Something that takes 5ish volt as input would be ideal.
Offline picandmix
That link does not work..
For a simple cheap sensor the DHT11 /22 range might do, though not I2c .
For a quality sensor then the Sensirion range is the way to go, though expensive.
http://www.sensirion.com/fileadmin/user_upload/customers/sensirion/Dokumente/Humidity/Sensirion_Humidity_SHT21_Datasheet_V4.pdf
https://www.adafruit.com/products/1638
Hmmm odd guess the link is cookied and only works on my PC.
This one might work: http://www.digikey.ca/product-detail/en/HIH6030-021-001/480-5704-1-ND/4291617
Digikey part # 480-5704-1-ND,    $13.70
I saw the DHT11 /22 too and it is an option but figured I'd check out i2c options first.
Offline eejake52
Several years back, I used a Honeywell HIH-3610 humidity sensor, combined with a DS2450 1-wire A/D. The circuit scavenged power from the 1-wire bus and there was some calculations required, but it did provide a fairly reliable reading of humidity in the cool-air return duct of my house.
