Author Topic: Fast immersion thermistor  (Read 573 times)
Offline maxwell3e10Topic starter
« on: May 29, 2020, 07:16:20 am »
I needed a fast temperature sensor for water temperature control and compared a couple of promising thermistor models. I thought I'd share the results here. Vishay NTCAIMME3 is the winner, it has a time constant of 1.1 sec according to my measurements and is quite inexpensive for an encapsulated sensor. Amphenol CR1 is a bare chip coated with water resistant coating. But despite having a much smaller mass, it actually has a slightly slower thermal response.
The following users thanked this post: thm_w, 2N3055
Offline RoGeorge
Re: Fast immersion thermistor
« Reply #1 on: May 29, 2020, 07:28:30 am »
In my experience, thermocouples were the ones with the lowest thermal inertia.
« Reply #2 on: May 29, 2020, 10:31:36 pm »
It's hard to get mK temperature resolution with a thermocouple. And it would still need to be protected from corrosion in a liquid.
Offline thm_w
  • Non-expert
« Reply #3 on: May 30, 2020, 12:12:45 am »
Yeah bare thermocouple will easily corrode in water causing some unusual readings.
For some reason I used to think the normal thermocouples you get with a DMM could be immersed.
