I'm liking the two circuits in the attached pictures
From
An ultraviolet nanosecond light pulse generator using a light emitting diode for test of
photodetectors. Tsutomu Araki, Yasumitsu Fujisawa, and Mamoru Hashimoto
Link:
http://scitation.aip.org/content/aip/journal/rsi/68/3/10.1063/1.1147943At least the ZTX-415 is made of Obtainium and is in production..
VA is 520 to 630V according to the publication. It would work at much lower voltages but the higher voltage reduced timing jitter walk. Cmax is 60 pf, above that the led is damaged. Cs in the lower circuit is for impedance matching, value ~ 330 pF, and R is about 60 Ohms, not 50, for best matching.
The risetime on the shockline circuit was not measured in detail, but the scope picture is very, very, nice.... The shockline pulse is flat-topped, the sort of thing you would want for checking scope bandwidth... However, it is a long pulse, having very desirable sharp edges.
I quote: "Because propagation speed of the current in the coaxial cable is 0.2 m/ns, resultant pulse width W in nS, is given as W = 10 D, where D is the cable length in meters"
Sadly they do not mention the cable type...
From looking at the scope photos, the emission mechanism for the UV shortens the optical pulse considerably, while the visible emission goes long with an afterglow.. So they used a UV filter for the obvious reasons..
Two LED, circuits operating with a slight delay between them, and combined with a beamsplitter, were then used to test the recovery time of their PMTs...
Their work is based on measurements done with a 12 Ghz scope and a 10 Picosecond sampling scope, so this paper is very valid...
LED used is a Model NLPB 520. from Nichia, and the spectrum splits,
I Quote:
"The 380 nm light originates from the InGaN/
AlGaN component, while the 450 nm light comes from the
doped Zn to which the energy is transferred from the InGaN/
AlGaN. Under the conventional dc operation below 30 mA,
the 450 nm light is dominant, and the intensity of the 380 nm
light is not appreciable. When a current larger than 50 mA is
applied, the intensity of the 450 nm light saturates, but that
of 380 nm light continues to increase. The 380 nm light
appears and fades rapidly, while the 450 nm light exists even
after extinction of the 380 nm light when applying a fast pulse"
Not as fast as things could go, but does not need SRDs made of pure Unicorn horn, the 415 is available from Digikey... I'd do it with logic gate edges, but that's just me...
Curiously, led life was limited to ~1.0 x 10^9 shots at 20 Khz, not from overcurrent or overheating, but from shock waves to the Die?...
Review of Scientific Instruments 68, 1365 (1997); doi: 10.1063/1.1147943
Steve
