Author Topic: Fastest four-pin optocoupler  (Read 2489 times)
Offline GallTopic starter
  • Country: ru
« on: September 04, 2011, 07:51:59 pm »
I wonder if they are fast optocouplers in 4-pin DIP packages. I know PC817 and equivalents, they are 4 us typ. I'd like to look at dual, triple and quad units too as long as they are pin compatible with 4-pin units stacked together (like PC827? PC837 etc.)
It's all about pin compatibility (direct replacement in someone's else bad design). I already know many parts for indirect replacement, no, I do not need more :)
The difficult we do today; the impossible takes a little longer.
Offline jakeypoo
Re: Fastest four-pin optocoupler
« Reply #1 on: September 09, 2011, 01:30:34 am »
You can lower the load resistance to increase response time as long as you don't go over recommended collector current.
If you want good performance I would stay with Sharp. PC813 series (pc823/pc843 [2/4 channel]) are quite good.
Obviously these are only pin compatible if the 4pin DIPs are spaced properly next to each other.
