@oldway Would it be possible, to use a "normal" transformer with taps and use full wave SCR controlled rectifiers to get the same 6 wave rectification. (Or maybe upgrade to 12 wave rectification with full wave rectifiers on a 6 phase transformer.) I know that means double the SCR and double the SCR loose. But I may make it back with a reduce size/weight/price of a normal transformer.
Yes, you can use full bridge SCR's rectifiers and 3 phase transformer, but, as you said, power losses on SCR's are twice higher....this can be a problem of efficiency at low voltage.
The two drawings are allright...
@Daniels: with 40A V to 166V ajustable units, look for the complexity of the comutations you will have to do.
- from 100 to 166V, you will need 5 converters in //
- from 166V to 332V, you will need 2 units in serie of 3 converters in //
- from 332V to 498V, you will need 3 units in serie of 2 converters in //
- from 498V to 664V, you will need 4 units in serie of 1 converter
- from 664V to 830V, you will need 5 units in serie of 1 converter
- from 830V to 996V, you will need 6 units in serie of 1 converter
CRAZY !
And the converters must be able to work with output voltage up to 1000V higher than ground...
High isolation is required.
@blueskull:
Smaller size --> better EMI performance. Not sure at all...you will have to make an ajustable power supply from 100 to 1KV and able to feed 200A at 100V and 20A at 1KV.
You probably will have to use a lot of units in //.
Dimensions seems not to be a concern.
SCR --> poor THD and PF --> your utility company will not be happy.: not right because;
- you will need a bridge rectifier to feed your converters and you will also have poor THD and high peak currrent with high rms value...your utility company will also not be happy
- full voltage range is divided in 3 subranges so phase delay in converters is limited and THD and PF stays acceptable.
- SCR technology is a well know and reliable technology, with few components and none of them are working in critical situation.
