If for argument sake, I wanted to sell a Finalized product that had WIFI, a built in Switch mode PSU, and various other RF noisy things and that the modules I used within that product where not FCC/CE certified, then I would assume that I would need to get the product FCC/CE certified if I wanted to sell it in large quantities.
However, what if I wanted to sell a DIY KIT of the same product, just with all the components either not soldered on, or partially soldered, but the end product is not complete until the hobbiest finishes it. Would I still need to get it certified or is that now down to the end user to do that.
For example, If I designed a module that is a WIFI SPI adaptor that would, say, be compatible with an Ardiuno development board, what I put together and sell is the WIFI chip, PCB antenna, on a PCB module, then the end use you put together the MCU (Arduino), PSU etc. IE they would need to solder it or jumber it to thier circuits.
Your thoughts?
