Hello,
100A surge on a 0.2R shunt is 20V, 20V over 4k is 5mA. I don't think 5mA is going to kill the chip.
Thanks, the thing is, our sense resistor is 1.2 ohms…so that’s 120V when a 100A surge flow through it. With the 4k resistor going into the MOUT pin, that’s then 30mA flowing in the chips ESD diode…that’s a lot.
Do you think we in fact must have either a zener or a diode chain across the sense resistor?
Why doesn’t the datasheet mention this?
The attached shows the issus...LTspice sim and pdf schem attached.
