Author Topic: suitable amplifier type to power LO ports  (Read 856 times)
Offline john23Topic starter
  • Country: aq
« on: February 11, 2025, 07:46:07 am »
Hello ,I need to choose an amplifier to power an LO port of two mixers with 17dBm power level at 10GHz without he following datasheets:
for this purpose I need to choose and amplifier with at least P1dB of 21dBm .
one amplifier is VGA (voltage regulated gain amplifier) and the other is a driver type.
What does it mean driver type amplifier does it fit to power the LO ports of my mixers?
mixers:
MM1-0320HSM-2_GaAs Double-Balanced Mixer
The MM1-0320HSM is a passive GaAs double balanced MMIC mixer suitable for both up and down-conversion applications. As with all Marki Microwave mixers, it features excellent conversion loss, isolation and spurious performance across a broad bandwidth and in a small form factor. The MM1-0320HSM...
markimicrowave.com markimicrowave.com
https://www.custommmic.com/resources/cmd258c4_ver_1.0_1017.pdf
amplifiers:
1. VGA type
http://www.analog.com/media/en/technical-documentation/data-sheets/hmc996.pdf
2.driver type
http://www.analog.com/media/en/technical-documentation/data-sheets/hmc608.pdf
Offline jwet
Re: suitable amplifier type to power LO ports
« Reply #1 on: February 11, 2025, 05:43:15 pm »
My non expert opinion, seeing that you got no responses.
Either would work certainly.  The driver amp is overkill for an LO amp.  A driver amp is designed to be in the power output path of a radio, close to the PA.  At these frequencies and at its power level, it could be the PA.  It's provides more power than you need but is ok.  Its kind of a power hog. (3x of the VGA)  The VGA's P1 db of 21 db gives you a little headroom and would do well at 17. You don't need the VGA function but its probably a better fit overall than the driver amp.  The output RL of the VGA is kind of going to pot at 10G.  Mixers can be a tough load.  Maybe the driver amp would be best for this reason.
« Last Edit: February 11, 2025, 05:46:57 pm by jwet »
Offline radar_macgyver
« Reply #2 on: February 11, 2025, 08:22:55 pm »
Use two drivers, one per mixer. This will improve the channel isolation. Once the max power requirement is reduced, you could use something like the HMC451 - much simpler to use (and cheaper) than the other devices. Add a 1 dB attenuator between the LO buffer output and the mixer LO port to improve the matching.
Offline Gerhard_dk4xp
« Reply #3 on: February 11, 2025, 08:49:46 pm »
I have used the HMC-451 with the HMC-220 mixer with quite good results.
Just saw that the hmc220 is EOL, still available but you want a single sideband mixer anyway.
« Last Edit: February 11, 2025, 08:58:51 pm by Gerhard_dk4xp »
