This will only work with short strains.
Because? Its one continuous length of wire, If it broken / cut somewhere down the length surely the tension cant' remain in it. ( granted i have not gone and practically tested this yet, its just been a mental experiement so far. I'm curious as to what i've missed. ( hence why i posted this in the first place! )
7 wires indicates a battened fence that will continue to hold some strain even if all wires are cut in the middle.
in deed, typical 7 wire farm fence, timber posts and battens.
Breaks indicate overstraining or some other fault in construction.
or it being deliberately cut, a car crashing into it, a tree falling on it.. and yes, failure due to construction.. ( i've spent several days fixing my own stuff ups, because i did'nt construct my strainer posts the right way. ( they call us sunday farmers for a reason, lol. ).. Nothign like a bit of experience to hone your fencing skills!
Sound fences are our only security and like you I have concern for their integrity. The route they take can have a lot to do with their general robustness from forces of nature or stock. Knowing stock habits and typical behaviour, even when stressed/driven has one hell of a lot to do with the longevity of a traditional NZ farm fence.
Present day materials, especially CCA treated posts and battens have an effect too, both galv wire and staples suffer from the copper in CCA treatment. For a while I used hot dipped post staples and they will typically last double the time of plain galv staples.
I've taken to adding a further wire to fences, a hot one from a real beefy mains unit. This keeps the stock from putting pressure on fences and discourages persons from unauthorised entry.
Still, you can't get away from occasional physical checks like they used to do in the old days. Hammer, strainers, wire and tools and ride the boundaries in particular. The best fencing advancement in recent times have been wire crimping systems like the Strainrite or Hayes products.
http://www.ezepullfencetools.co.nz/http://www.hayesfencing.com/product.asp?categoryID=4Getting back to some loop sense....there was a single staple insulator, its plastic part was within the staple and while today it's totally useless for high power energisers it would be OK to provide insulation for a return system.
Can't remember who made them.............
