Hi ajb and thank you for you response,
(FFC connectors are often only rated for a couple dozen mating cycles!)
I totally agree with you!! In the previous prototyping version, I included an FFC ZIF connector and I end ti up with a broken actuator after some cycles. That's the reason I want to avoid FFC connectors with actuator this time.
Lots of people like the Tag-Connect cables, so that's an option as well.
Ok, I didn't even know about this type of connector. It looks promising for my application and they provide accessories as well to combine it with my J-Link debugger. Thanks for your suggestion!!
or use with a little pogo pin adapter for programming.
Do you something in mind? or you are just referred to the Tag-connect cable?
