I'm looking for a 5V->3V/3.3V linear regulator with low leakage current (1uA and less) in reverse powered configuration.
There's an USB powered device with optional battery backup.
During normal operation 3V bus is generated from 5V bus, and everything is OK.
However, when USB power is missing, neither LDO itself nor 5V bus powered circuit must suck the battery.
A diode at LDO input solves one half of the problem, but the other half with 3V-to-GND leakage remains.
Other requirements:
Load current could be as low as 10mA, however, since widely available LDOs provide at least 50-100mA and above it's likely any one of them will fit.
Output short-circuit protection, this thing must be unkillable. Small SMD package like SOT89 or SOT23, maybe some DFN or alike.
