Author Topic: Adapter Boards  (Read 1908 times)
Offline docmurTopic starter
Adapter Boards
« on: January 28, 2017, 06:20:51 pm »
Hey Guys
Does anyone have any recommendations where I can get adapter boards for 4-PLCC -> DIP (for LED's) and SOT23-5 -> DIP?  I found boards for ~$3 a board but I was wondering if anyone knows anywhere cheaper?  Digikey doesn't have any 4-PLCC -> DIP boards at least as of right now.
Thanks
Docmur
Offline Vtile
  • Ingineer
Re: Adapter Boards
« Reply #1 on: January 28, 2017, 06:31:43 pm »
It always amaces me that these adapter stamps are so super expensive, must be a good business.
Online Ian.M
Re: Adapter Boards
« Reply #2 on: January 28, 2017, 07:11:09 pm »
If you want pre-assembled with headers, you'll pay a premium.  If you are happy with bare board, there are considerable savings to be made.
I *think* PLCC-4 would fit on Tripad board (0.1" pitch stripboard with the strips cross-slit every three holes)   If so http://www.ebay.co.uk/itm/Veroboard-Copper-Tripad-Board-100-x-160mm-/401035221181 would be enough for 130 parts (allowing 3 strips across for ease of cutting straight down the line of holes in the middle of a strip, then cut every 6 holes along the cross slit).  Offer one up to a piece of nomal stripboard and see - Tripad cross-slits are the same with as the slits between strips.  If you are UK based, its stocked by Maplin Electronics.  I cant find any international suppliers.  :(
Sparkfun do SOT23-6 breakout boards for $0.95: https://www.sparkfun.com/products/717 and Adafruit do a set of 13 breakout boards, 5 of which are SOT23-6 for $4.95: https://www.adafruit.com/product/1230.  Both can also be found at various resellers . . .
« Last Edit: January 28, 2017, 10:02:45 pm by Ian.M »
Offline james_s
Re: Adapter Boards
« Reply #3 on: January 28, 2017, 07:38:05 pm »
You can get various breakout boards on ebay, sometimes I just make my own when I want to prototype something. It's also possible to prototype on perfboard even with very small SMT parts. Check out some of the projects on http://elm-chan.org/ for examples.
Offline bson
Re: Adapter Boards
« Reply #4 on: January 28, 2017, 09:52:50 pm »
I use SOT23 adapters I got a 50 pack of from an eBay seller (China or Hong Kong, forget).  They're 10 pin with 0.95mm spacing on one side and 0.5mm on the other.  Something like an SOT23-3 obviously only uses 3 pads, but that doesn't terribly matter as long as I can get it into a breadboard.
Offline jc101
Re: Adapter Boards
« Reply #5 on: January 30, 2017, 12:34:48 pm »
I have recently used some SO8 adapter boards for PLCC-4 LEDs, they worked very well.
