If you transform the solar power battery, youll get more into your battery because it has more volts.
But I guess you dont need it because you just put your panel in series, anyway.
But I wonder if you put it through a transformer as well just get it maximum voltage possible (maximum psi) before you go into the battery, and more residuals will go through?
