In case anyone is interested, the code for the receiver in stripped down version. This also shows the configuration we use for the NRF24L01.
Based on the example from
https://github.com/maniacbug/RF24/*
Copyright (C) 2011 J. Coliz <maniacbug@ymail.com>
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
version 2 as published by the Free Software Foundation.
* Example for Getting Started with nRF24L01+ radios.
* This is an example of how to use the RF24 class. Write this sketch to two
* different nodes. Put one of the nodes into 'transmit' mode by connecting
* with the serial monitor and sending a 'T'. The ping node sends the current
* time to the pong node, which responds by sending the value back. The ping
* node can then see how long the whole cycle took.
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include <Adafruit_DotStar.h>
// Hardware configuration
const int ledPin = A0;
const int buttonPin = A1;
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(9,10);
// Topology
const uint64_t pipe = 0xF0F0F0F0E1LL;
// Role management
// Set up role. This sketch uses the same software for all the nodes
// in this system. Doing so greatly simplifies testing.
// The various roles supported by this sketch
typedef enum { role_ping_out = 1, role_pong_back } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"};
// The role of the current running sketch
role_e role = role_ping_out;
void setup(void)
pinMode(ledPin, OUTPUT);
// Blink to welcome our new robot overloards.
digitalWrite(ledPin, HIGH);
pinMode(buttonPin, INPUT_PULLUP);
// Print preamble
Serial.begin(9600);
Serial.println("\n\rRF24/examples/GettingStarted/");
digitalWrite(ledPin, LOW);
// Setup and configure rf radio
radio.begin();
// optionally, increase the delay between retries & # of retries
radio.setRetries(15,15);
radio.setPALevel(RF24_PA_MIN);
radio.setAutoAck(0);
radio.setDataRate(RF24_250KBPS);
// optionally, reduce the payload size. seems to
// improve reliability
radio.setPayloadSize(8);
// Open pipes to other nodes for communication
radio.openReadingPipe(0,pipe);
radio.openWritingPipe(pipe);
// Start listening
radio.startListening();
// Dump the configuration of the rf unit for debugging
radio.printDetails();
void loop(void)
// if there is data ready
if ( radio.available() )
// Dump the payloads until we've gotten everything
unsigned long got_time;
bool done = false;
while (!done)
// Fetch the payload, and see if this was the last one.
done = radio.read(&got_time, sizeof(unsigned long) );
// Spew it
Serial.print("Got payload ");
Serial.print(got_time);
Serial.print(" ");
// Delay just a little bit to let the other unit
// make the transition to receiver
delay(20);
unsigned long waittime = got_time & 0xFFFF;
Serial.println(waittime);
//delay(50);
// Send the final one back.
// Now, resume listening so we catch the next packets.
