Thanks! No idea how i managed to miss that one! Even lists EPAS as suggested use!! ;-)
BTW, if anyone wants a cheap low voltage, high current H bridge, modifying this power steering controller looks to be a cinch, as the entire power stage is separate to the control PCB:
It has input and ouput isolation (via 2 relays), filter caps, H bridge via 4 of those FETS, and even a current sensor, all built in! And all the control and feedback is via through hole pins that stick up through the control pcb. it would be dead easy to do your own control pcb!
