Author Topic: Hilbert filter designer iowa hills  (Read 1774 times)
Offline salviadorTopic starter
    • https://www.youtube.com/user/mancio92M
« on: June 03, 2023, 05:15:43 pm »
I can't find the "iowa hills hilbert filter designer" free software.
Does anyone know where I can download it?
(the original site hasn't been working for a while)
Thank you
Online RAPo
Re: Hilbert filter designer iowa hills
« Reply #1 on: June 03, 2023, 05:21:05 pm »
Offline coppice
« Reply #2 on: June 03, 2023, 05:23:15 pm »
Thank you
I don't know what the Iowa Falls software does, but if it just designs the usual FIR implementation of a Hilbert transform that is so simple it really doesn't require special tools. If you want one of those tricky Hilberts that shifts both the real and imaginary so they are mutually 90 degrees apart at all frequencies, that does require some clever tricks. Even that is only a couple of pages of Matlab.
Online coppercone2
« Reply #3 on: June 03, 2023, 05:36:13 pm »
i want the original software too, it sounds interesting, mat lab does not
Offline coppice
« Reply #4 on: June 03, 2023, 05:46:16 pm »
Build it yourself from: https://github.com/hayguen/iowahills_dsp
That's not the source for the designer. 30s of arduous Googling got me to this page https://www.reddit.com/r/rfelectronics/comments/z0bz78/iowa_hills_filter_software/ from which someone seems to have made a backup copy of the Iowa Falls software on a Google drive account.
Offline radiolistener
  • Country: ua
« Reply #5 on: June 03, 2023, 10:53:34 pm »
these tools have very bad dynamic range and very limited tuning options. It can be used for a simple filter with low dynamic range.
MATLAB allows you a lot of options to tune it and provide very good dynamic options. It allows you control almost everything and in addition to show the frequency and phase response with any details and even perform test DSP for a WAV file. It allows to optimize cofficients for specific hardware, compare result for for fixed point and floating point coefficients, add compensation and many other features, like different algorithms for filter calculation and optimizations depends on your needs and even more it can produce FPGA or C code and other :)
« Last Edit: June 03, 2023, 10:58:49 pm by radiolistener »
Online coppercone2
« Reply #6 on: June 05, 2023, 05:30:57 am »
I believe you but a simple app that can offer a solution without a project to implement is golden
