Thanks TerraHertz
I wasn't planning on removing my name from the pics but now that you mention it I guess it wouldn't hurt.
So, what's the max output current at 12V, and efficiency?
Well the official documentation shows it's a 96W converter with 8A output. However, in practise the output rectification diodes would be getting mighty toasty at ~50W. So I guess I'll always remember to double check my diode power dissipation equations before sending the PCB design away for fabrication.
Also, it was only tested at 12W output and the efficiency wasn't tested. Due to the high voltages I could only test it under supervision and I couldn't organise a supervisor for long enough to run every test I wanted. It does really bug me though not knowing it's efficiency, it's the first test on the list for when I get a high voltage supply.
Who'd you get the board manufactured by, and what was the cost?
I have no idea actually, the uni took care of it all. I submitted the PCB layout to the uni by a deadline and then I got it back some weeks later. It was sort of annoying actually as I wasn't allowed to just fabricate the PCb at uni or send away to a manufacturer of my choice.
I don't suppose you have a list of all the texts and online references you used while designing this?
Yeah there were a fair few, if you want I can PM you my thesis with the full list, I think the main ones were:
LLC:
1. (SLUP263) Texas Instruments, “Designing an LLC Resonant Half-Bridge Power Converter,” design review, in Texas Instruments Power Supply Design Seminar SEM1900, 2010.
*If you can't find this online send me a PM as I have a copy saved*2.Yang, F.C. Lee, A.J. Zhang, G. Huang, "LLC Resonant Converter for Front End DC/DC Conversion," in Seventeenth IEEE Applied Power Electronics Conference and Exposition, 2002, pp. 1108-1112.
3. G. Hsieh et al, “Design Considerations for LLC Series-Resonant Converter in Two-Resonant Regions,” in IEEE Power Electronics Specialists Conference, 2007, pp. 731-736.
4. B. Lu, W. Liu, Y. Liang, F.C. Lee, J.D. Van Wyk, "Optimal design methodology for LLC resonant converter," in Twenty-First IEEE Applied Power Electronics Conference and Exposition, 2006, pp. 533-
538.
Current Doubler Rectifier:
1. A. Ioinovici, “Derived Structures of DC-DC Converters,” in Power electronics and Energy Conversion Systems, Vol.1, John Wiley & Sons, 2013, pp. 705-721
Are you going to publish the complete schematic, parts list and suppliers details?
Yeah good point, I'll try and post that tomorrow along with some Matlab scripts.
Switchmodes are something I've never designed apart from a few extremely trivial cases, but I'm very interested in doing so in the future. So, much need for learning. I find resonant converters hard to visualize, and this would be fun to build and play with.
Yeah, I didn't go too far into the maths behind the resonant converter, I stopped once I could plot the gain vs frequency graph I showed earlier. I think deriving all the maths behind it would have taken me more than a year.
