Author Topic: Why do ATX Power Supplies Have So Many Parallel Connections?  (Read 1465 times)
Offline PoshTopic starter
Hi all,
I've recently been tearing down various ATX PSU's for use in other applications, and after cutting down a few forests worth of wires, I've been wondering why all the parallel connections are needed at all?
I understand that the motherboard connectors have multiple pins that need power to be delivered, but why use multiple grounds and power pins in the first place?
Surely it would be more economical and 'clean' to simply use less wiring at a thicker gauge if resistance is the issue...
Cheers,
Posh
Re: Why do ATX Power Supplies Have So Many Parallel Connections?
« Reply #1 on: June 19, 2016, 03:58:25 am »
To carry the current, nothing more.
Check the current capabilities of such a PSU and then try to put all that current down just one of those conductors, sorry it won't happen.
Now think of all that current flowing through just one pin of those multi pin connectors, again: won't happen.
Further, think of all that current terminating into just one PCB trace: won't happen.
They're a computer supply not a BBQ.  ;)
The following users thanked this post: Posh
Online Phoenix
« Reply #2 on: June 19, 2016, 05:25:23 am »
A lot easier to route, terminate and connect multiple smaller wires to a pcb.
Online Alex Eisenhut
  • Place text here.
« Reply #3 on: June 19, 2016, 06:01:50 am »
Pretty sure that a loom of smaller wires is also a lot easier to bend and route inside a crammed PC case.
