The supply is 220v 50Hz ac.I need 60V DC output voltage .For this i need to fire the thyristor at 80
degree.The main problem is to fire the thyristor at 80 degree .please sugest me the firing circuit.
for half wave controlled rectifier
Vdc=Vm(1+cost)/2*pi
here t=firing angle
Vm=maximum ac voltage
Vdc=output DC voltage
So for Vdc=60V ,Vm=1.414*220=311
t=?
the required firing angle would be 80 degree.
so please help me how i can fire the scr at an angle 80 degree.
If you need 60V out of 240V, why do you have to use an SCR? Why not keep it simple and just get a transformer to step the voltage down and rectify/filter the output?
If you have to use an SCR and need to fire the trigger at a precise point in time, you will need to implement a zero crossing detector on the mains supply and then use a timer to delay the trigger.
I remember building an SCR trigger when I was at uni which was based on a 555 timer for generating the delay with a zero crossing detector based on a comparator sitting on the output of a small stepdown transformer. Don't remember much of the details now though... was a few years ago...
