Author Topic: NMOS inverting amp with negative VDD?  (Read 1568 times)
Offline Chad1Topic starter
« on: June 21, 2012, 09:50:52 pm »
Hi guys,
I'm trying to design a circuit using only an N-FET and a resistor that performs with the basic inverting amp characteristics, but I want it to work with both a + and - VDD. Any suggestions? I'm sure this spec will require more components than an N-FET and a resistor. I tried to come up with a circuit that introduces a diode in series with GND so that when Vin (gate) is pulled low, Vout is VDD (where VDD<0). Below is a truth table of what I want (the last line is the only one that is a problem):
Vin (VDD>0)      Vin (VDD<0)         Vout
  high                                               0
  low                                              VDD (>0)
                             high                    0
                             low                   VDD (<0)
                 VDD
              R   \
             -----o----------o Vout
Vin ----|
                 GND
Thanks a lot!
