Author Topic: Tolerance Analysis: Is Resistor TCR a Normal Distribution or Maximum?  (Read 2519 times)
Offline TimNJTopic starter
Hi all,
I'm working on preparing a tolerance analysis for a power supply. I'd like to estimate the spread of output voltages in production. The output resistor divider is one of the key circuit blocks which will determine the accuracy of the output voltage.
I am attempting a root square sum (RSS) method. I was planning on using the following parameters:
  • Initial Tolerance
  • Shift after Soldering
  • Temperature Coefficient (TCR)
We can assume the initial tolerance and shift after soldering is normally distributed (even if that might not be 100% the truth). But for TCR, is this reported as a typical value or worst case? If it's typical, then perhaps it can be considered a normal distribution? On the other hand, I would imagine the TCR for a particular material to be rather constant. That is: Perhaps the distribution is much narrower?
Thanks in advance,
Online coppercone2
Re: Tolerance Analysis: Is Resistor TCR a Normal Distribution or Maximum?
« Reply #1 on: April 05, 2019, 03:56:36 pm »
it will depend on the manufacturing process. The manufacturer has a spec to cover their ass and their production run is probably going to be more accurate then the tolerance so they have a smaller defect rate. They will also probobly want to give you stuff a bit better because of drift and warranty claims. All those resistors have some small chance of drastically changing in value (to a  reasonable degree of course) because of internal strains and stuff, most likely.
For good manufacturers, you buy 50ppm resistors (say yaego) you will get stuff like (+-) 5ppm, 14ppm, etc. You have some over head but when you make something you need to base its spec on the manufacturers values unless you test the resistors yourself. Trying to game unspecified curves is horse shit design unless you test. And even then, you have NO IDEA if maybe those resistors might have some tendency to go off 40ppm after a year after soldering despite initial 5ppm, which would bring em to 45ppm within spec.
But say chinese cheapo resistors, you buy 50ppm its going to be like 40ppm, 50ppm.. very close to spec. No head room for unanticipated drift.
If you sell measurement equipment you don't wanna have problems because your design probably works. Keep it simple because its more respectable.
This kind of stuff is only useful for giving 'typical' values in your spec sheet.
« Last Edit: April 05, 2019, 04:00:55 pm by coppercone2 »
Offline RandallMcRee
« Reply #2 on: April 05, 2019, 03:59:44 pm »
I have always assumed that it is typical.
There is a lot of evidence in various threads in the metrology section that suggest it is actually "optimistic" rather than typical.
My evidence is anecdotal, so hopefully, someone will reply with real production data. Resistors I have measured tend to go for the typical bucket, except for Vishay S102C which are in the optimistic bucket, e.g. usually worse than typical. Susumu RG were in the typical bucket, however.
In any case, TCR is not, to my knowledge, ever a 100% tested parameter. So there is that.
« Last Edit: April 05, 2019, 04:01:53 pm by RandallMcRee »
Online coppercone2
« Reply #3 on: April 05, 2019, 04:02:48 pm »
Well I am just saying you don't sell typical, you sell a spec and hope typical is a incentive for people to buy. Typical better then spec shows you know what your doing.
Dave jones has a video. What he found that from a particular batch you get some offset within the tolerance with a bell curve.
Giving people a probability density function of your equipment meeting a specification is unheard of. With individual testing its better but you still don't know if those resistors have some kind of manufacturing 'plot' behind them in regards to time, and the manufacturing process is not guaranteed by manufacturer not to change. This means more testing cost. If you do environmental testing and you do everything to spec you can decrease your sample size because you are more confident. And you can rest easier with your reputation, because then you are allowed to pass the buck to manufacturer of resistors if someone inquires about design and it looks solid.
« Last Edit: April 05, 2019, 04:08:00 pm by coppercone2 »
Online coppercone2
« Reply #4 on: April 05, 2019, 04:08:16 pm »
Not to say your analysis is not useful. You can get good data regarding 'typical' specification (hey this stuff is good and manufacturer is careful), and you can get good data to give a reasonable calibration interval based on confidence. Instead of slapping random calibration intervals on it. That stuff saves people money and time too, if they need to calibrate less often, or if they honestly know it needs to be frequently calibrated so they don't randomly decide every year when it needs to be 6 months. Realistically you want longer calibration intervals because higher stability is a angle a competitor will use against you, so it tell you that you need to improve your design or loosen your spec if you know its actually difficult to design something better). Unless its just awesome and they just need to deal with how finicky it is.
« Last Edit: April 05, 2019, 04:30:23 pm by coppercone2 »
« Reply #5 on: April 05, 2019, 04:37:15 pm »
Note to the OP: Those posted videos are concerning the Distribution of value, *not* TCR.
If anyone knows of similar information (100 resistors all measured for their TCR) that would be interesting. But, I don't believe that you can take the PDF of the value and say anything at all meaningful about the TCR.
(I think the message here is: design something that tolerates a wide range in TCR, if at all possible)
Offline iMo
  • Country: bj
« Reply #6 on: April 05, 2019, 05:00:50 pm »
Here is a document dealing with TCR's statistical data and definitions - maybe somehow useful..
https://www.vishay.com/docs/60108/nonlinea.pdf
« Reply #7 on: April 05, 2019, 05:20:51 pm »
Thank you all.  :)
coppercone2, you seem to suggest that a 50ppm spec implies the ΔR/R should be less than 50ppm, for a given sample. On the other hand, RandallMcRee, you seem to imply that the TCR is likely a typical spec, though not all typical specs are created equal.
I'm aware of the limitations of the analysis. I really just want to see if we're going to be in the ballpark to meet our specifications.
imo, thanks I'm giving it a look.
« Reply #8 on: April 05, 2019, 07:22:28 pm »
It's an interesting document. Am I missing it completely or do they not include the sample size from their six vendors?!
Online coppercone2
« Reply #9 on: April 05, 2019, 07:46:54 pm »
I only measured 5 resistors for TCR from a batch like that (yaego) vs chinese (random amazon) ones. I don't remember the Chinese but the yaegos were rated 50ppm, and had a spread of drift from like 4-20 ppm. Nothing to close to the 50ppm spec with my short term test.
The problem is fixture and time, it takes forever to do this (if you reuse the same fixture so you get the exact same thermal results). I thought about  making a big one that I can multiplex or something, but it turned out to be too much effort for no application to any of my projects.
« Last Edit: April 05, 2019, 07:50:58 pm by coppercone2 »
« Reply #10 on: April 05, 2019, 07:47:53 pm »
Hey again guys.
I've been working from this document all day: http://www.ti.com/lit/an/snva112a/snva112a.pdf
They provide a lot of the theory right up to the calculation, and then leave you high and dry, without showing any work.
For an output divider + reference voltage circuit, the equation for variance is shown below:
First off, I'm confused as to the usage of "variance" here. For example, in the equation,  V(R1), V(R2) and V(Vref) are the variances of these components. But the statistical variance is not something we are provided. Components are given a "tolerance", which we might assume is the spread of values out to 3 or 6 sigma. One sigma is the square root of the variance...
But they don't seem to talk about that at all. They only talk about 0.5%, 1% or 5% tolerances. Is it possible that V(R1) is really the tolerance of R1? Does that even make sense?
And then...once you get the variance of the output voltage, do you have to take the square root of it to get sigma, and then multiple by 3 or 6 to get the expected spread? Yikes this is more confusing than it looked.
« Last Edit: April 05, 2019, 07:50:09 pm by TimNJ »
