i have take apart a power supply and came accross a construction Dave showed as well in one of his teardowns (see attached image).
In the image you see lines L1 and L2 entering from the bottom, passing a fuse and an NTC. Then there seems to be an emc filter. But what i don´t get are the spark gaps being "parallel" to the current compensated inductors. Has anybody got a clue what they are being used for in this case?
Not drawn in the picture: after the inductors a four-way- rectifier is applied...
Thanks a lot..
