I'm looking for the best method to boost the output from a single cell Li battery to about 24V. I only need roughly 2mA output @ 24V, but I want the highest efficiency and lowest noise possible.
Simply current source wise these are if perhaps not conflicting requirements, but they are complicating requirements.
The simplest low noise high side current source would be a capacitance multiplier followed by a two PNP transistor current source ... but that needs around ~3 diode drops (actually two diode drops + Vcesat minimum) so that's 7% down the drain from the start.
There are current sources with lower voltage drops, but keeping it just as low noise and high ripple rejection as that extremely simple circuit is not necessarily easy. How about designing for low noise and reasonable efficiency? Then you can use the above current source and shoot for say 80% efficiency overall (with a boost converter which keeps the supply voltage to ~2V above the current source output voltage).
Current loop sensors sacrifice efficiency from the start to begin with, so what's another 10%.
PS. unlike in your link you really need better ripple rejection, because of the switching power supply, that's why the capacitance multiplier.
