Author Topic: JLCPCB 6 layer 2313 stackup confusion  (Read 3196 times)
Offline sinkTopic starter
« on: February 01, 2021, 04:43:07 pm »
Good evening everyone,
I'm working on open source software defined radio based on XC7Z020.
Now I'm thinking about the stackup, and I'm considering 6 layer (top)S-G-S-G-S-G(bottom).
I'm confused, because when i use jlcpcb impedance calculator to calculate 50 ohm SE traces for high speed data, I end up with 21 mils width. It's too much, especially for DDR3 memory. Should I calculate it on my own, in separate pcb calculator?
[ Specified attachment is not available ]
If so, does somebody know the permeability value of core present in 6-layer 2313 type stackup?
I need it to calculate the width of digital traces.
Offline profdc9
Re: JLCPCB 6 layer 2313 stackup confusion
« Reply #1 on: February 01, 2021, 05:05:49 pm »
This calculation doesn't seem out-of-line at least if the dielectric is FR4.  I tried it with Pasternack's calculator and got similar results:
https://www.pasternack.com/t-calculator-stripline.aspx
« Reply #2 on: February 01, 2021, 05:12:59 pm »
You use 4.2 epsilon_r, and according to stackup, there is one dielectrical core with unknown epsilon_r 1163382-0
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #3 on: February 01, 2021, 05:23:26 pm »
If possible route the DDR3 traces on the top layer.
« Reply #4 on: February 01, 2021, 05:26:44 pm »
I don't think it's possible, doesn't matter how hard I will try.
I hope jlcpcb calculator is just faulty.
Offline thinkfat
« Reply #5 on: February 01, 2021, 05:28:25 pm »
That is not an assumption I'd base a design on.
Offline profdc9
« Reply #6 on: February 01, 2021, 05:29:28 pm »
In the diagram it says Er1:  4.6, Er2: 4.25, Er3: 4.6.    I would assume that JLCPCB would put the correct values of dielectric constant in their calculator for the JLC2313 process.   Could the actual dielectric constants of the layers be different than these values?
The following users thanked this post: RichardS
Offline thinkfat
« Reply #7 on: February 01, 2021, 05:31:56 pm »
I'd just ask them.
« Reply #8 on: February 01, 2021, 11:29:35 pm »
Thanks everybody, I will ask JLCPCB, and then write what I found out!
Offline tszaboo
« Reply #9 on: February 01, 2021, 11:44:14 pm »
That could be the problem. Typically a 6 layer board is S-G-P1-P2-G-S, or S-G-S core S-G/P-S
Offline thm_w
  • Non-expert
The following users thanked this post: thinkfat
Offline JLCPCB Official
  • Country: hk
« Reply #11 on: February 02, 2021, 07:25:35 am »
(Attachment Link)
dear sir, JLCPCB will follow up your case. If you need it, you can PM me your registered email. [of course, we will protect your privacy and your design. Thank you!]
« Reply #12 on: February 16, 2021, 09:31:51 pm »
Hello everybody!
I just figured out what was wrong.
When I select 6-layer board, and inner layer, JLCPCB's calculator assumes, that I want to use as ground reference L2 and L5 - and signal layer L3 - so I would have to leave L4. So instead of S-G-S-S-G-S I wanted and still want to use stackup S-G-S-G-S-G.
The solution is simple. Just use different calculator with dielectric constant values from JLCPCB site :D
Thanks!
« Last Edit: February 16, 2021, 09:33:51 pm by sink »
