I've been trying to come up with a really small design that will take mains line voltage in the range of 90-250 volt a/c - 50/60 Hz and output
5 / 3.3volt at < 500mA.
I don't want to use a big transformer+linear regulator because of the size !
I've seen implementations like Microchip AN954, (capacitive and resistive PSU):
But they seem unsafe and I don't like them, I'm looking for something more robust.
I found the fly-back converter with secondary current and voltage regulation implementation, commonly found on wall adapters for cellphones.
Then I located the ViPer family of devices from ST, specifically the ViPer12A which can handle a bulk and flyback configurations.
It provides some sort of protection and I like them, they come in DIP package and most important I can source them in my town !
From the app note "
AN1484":
The circuit is a standard Flyback converter with secondary current and voltage regulation driving the VIPer12A feedback pin through an optocoupler.
This is the design I was looking for !, it's small, safe and it's been used all over the world but I know nothing about them
I feel I'm going through the rabbit hole and things get complicated every step of the way.
First and most important it's very hard to find the correct flyback transformer, the two vendors I found don't have a sales webpage they work only
through distributors, and even then I'm not sure about the stock.
PF0037 From Pulse
CVP11 Series from Cramer Coil
Future reading I found that I could buy a EE16 core and wind the transformer myself but I know nothing about that either.
EE16 Cores
I've some questions that google can't answer.
Can you manually wind a tiny flyback transformer ?
If someone has experience with these designs I would greatly appreciate any advice.
Thanks.
Ben.
