EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Bandpass filter design
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Bandpass filter design (Read 1722 times)
jbushnel
Contributor
on:
December 15, 2014, 02:42:59 pm »
I was going to order this kit from jameco but I had some questions about the filtering!
http://makezineblog.files.wordpress.com/2010/10/ledcolororgan-schem_r2.gif
I wanted to pretty much keep everything the same but I wanted to change where the bandpass occurs (and maybe slightly change the bandwidth). I noticed that the only thing that changes for each filters are the three capacitor values. How would I go about choosing the values for the filter components? I have done an "online filter calculator" but all of the values are not as rounded as the one in this schematic...
To me, they look like third order filters: The first two stages is an active filter where there is multiple feedback. Then the third stage is the passive high pass filter that is connected to the output of the op amp. I don't know how to go about fitting it for my need. Thanks!
Logged
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Re: Bandpass filter design
Reply #1 on:
December 15, 2014, 03:12:07 pm »
If you keep the resistor values constant and vary the capacitors in proportion, the break frequency will vary in direct proportion as well. As such, you can round the values to the nearest common value to get something pretty close.
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
