Author Topic: Fourier Series (Sawtooth Approximation)  (Read 1422 times)
Offline @rt
« on: October 31, 2015, 11:56:36 am »
Hi Guys :)
Could someone explain why there are two different circular animations about YouTube for Fourier Series Sawtooth animation?
Here’s one example where every second circle is rotating clockwise:
Yet the Wikipedia example here is different:
Wouldn’t these be two entirely different formulas?
At the very least I think theta would alternate positive and negative for the first example only.
I put this in projects section because it is a software project. I have been making my own.
Cheers, Brek.
« Last Edit: October 31, 2015, 11:58:19 am by @rt »
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Fourier Series (Sawtooth Approximation)
« Reply #1 on: October 31, 2015, 12:20:16 pm »
Probably, because cos(-x) = cos(x)?  For even harmonics, the direction of rotation doesn't matter, because they always have the same vertical component relative to the rest.
Seven Transistor Labs, LLC
Offline @rt
« Reply #2 on: October 31, 2015, 12:30:39 pm »
Lol can we forget the whole thing and make this thread go away? :D
There must be an issue with my rotation.
When I reproduce the second animation, as the iterations get near 200 or so,
the sawtooth becomes as good resolution as infinite is going to get on a limited resolution screen.
I can explain and fix the jittery points (it’s because I’m only connecting every third sample).
When I reproduce the first one it’s great except there’s a little kink in the middle of the diagonal part of the wave.
That is not uploaded though... I’ll look into it again :O
