I have just made my first design using an FPGA (until now i have always used dev boards) and am having some issues with it.
I am using the MachXO3-9600C-6BG256C FPGA from lattice to drive an LED panel with data stored in external RAM.
So far i have got the thing to output test data to the panel but am stuck making it read the ram.
The problem is now, that changing some things that should not affect anything else (like outputting a signal to another pin for debugging) will make the entire thing stop working. (it is honestly quite hard to explain
For example: there was an issue with an internally divided clock (just a bit from a counter), which only ran at ~100Hz instead of the 30MHz intended. But once i assigned it to a debug led output (LED <= clk30;) it just worked again.
Or changing a divider ratio (in an entirely different module!) caused an addition not to execute (sig <= sig + '1') or a bit to not be set sometimes (litterally randomly as the thing was running).
Or a memory address calculation (currPixAddress <= ram_currColor + (nextLine+ram_currLine * x"20") * x"180" + (ram_currPix * x"3")) worked until i assigned it to the address input of an internal ram IP, then it just stayed at zero.
Unfortunately my head has now given up trying to understand what is happening
and i have no idea where i can even start debugging (i have already tried to decrease the master clock speed from 200MHz to 100MHz and 50MHz)
I am also pretty much a noob when it comes to FPGAs so i dont really know what this could come from or how to properly explain the issues i am having (if it doesn't make sense what i wrote please ask and i will try to explain it better).
are there any standard debugging procedures i can follow?
