I was lucky enough to be able to get one of these cards to try out in my 8563E. For those not familiar, unlike the 8590E series, the 8560E series doesn't have a card slot on the front. It uses something called the 85620A Mass Memory Module. This module has a slot in it that you can put a card into.
Having played around with writing some code to access the card, I'm pretty sure that the intent of this slot was to be used to deploy DLPs to the memory module, and not as a medium for storing information. I say this because functionality that you would think should be there really isn't, for example, you can use DISPOSE ALL to clear the memory of the mass memory module, but not the card. You have to format the card to clear it, or manually delete each file on the card from the 8563E. However, you can't format it over GPIB, or at least I couldn't work out how to get it to format (you can issue a FORMAT command, but it appears to then be waiting for some additional parameters that should be the number of entries, but aren't).
Now, clearly, they did have some use case for a RAM card as they offered the 85700A & 85702A cards, but in my opinion, the implementation of the RAM card usage was pretty poor, so I have to believe that the use case was niche.
Anyway, this isn't a problem for me because what I wanted the card for was to act as a backup for my 85671A & 85672A DLP-based utilities (having let the battery fail in my 85620A I lost them. Upside, this led me to write a utility that you can use to push the DLPs back to the module from an image on KO4BB's site -
https://github.com/TGoodhew/DLPBits).
So I wanted to just describe my experience with it. Overall, the card is well-made and of high quality. Serious applause to Miti for creating it, really well done.
It fits nicely into the slot in my 85620A:
Slotting the module back on the SA and the card is identified:
Can be formatted and written to using the SA:
If you have an 8590 series SA or really need the ability to move stuff between 8560 series SAs then I would absolutely recommend the card if Miti does a run of them.
The two issues I had are, firstly, the card sits a bit proud of the top of the SA when installed:
I'm not sure if that was also the case with the original cards; I have never actually seen one, but it might be something to consider in a v2 product.
Secondly, it seems that the 8563E (and I assume the rest of the 8560E family) will only see ~112KB of space (114432 bytes)- Not an issue with the card though, just a limitation I think in the SA.
If anyone has questions, please let me know.
TonyG
