Author Topic: So, I am trying to breadboard this amp  (Read 1109 times)
Offline HextejasTopic starter
« on: March 16, 2018, 12:18:15 am »
And other than a bit of heat, thatscall the output. I don't know how to debug it. Plus I have a question.
I have a small scope and I can see the 1k Hz test wave until it hits the BC550C. Where else should I look and for what ?
I did not design this but others have built it successfully and liked it so I thought that I would give it a try.
What is the reason to put the sine wave onto the gate of the BC550C ?
Offline LeoTech
  • High School student with a passion for electronics
Re: So, I am trying to breadboard this amp
« Reply #1 on: March 16, 2018, 07:41:51 am »
Well, are you sure this schematic is correct?
Because for this to be an amplifier it needs an input, output and a power supply, and as far as this particular schematic goes, there is no output.
Although I would presume that the output is the 8 ohm resistor (R11), pretending to be something like a speaker or so? Please clarify this and I(we) will be able to assist you further.
Leo
High School student with a passion and interest in electronics, both analog and digital!
Offline Audioguru
« Reply #2 on: March 16, 2018, 03:00:53 pm »
You need to learn about transistors to understand how the circuit works.
The BC550 has a base for its input, not a gate. A BC550 is a bipolar transistor, but a Mosfet has a gate for its input. This circuit does not have a Mosfet.
The output power of this amplifier is very low but it produces a lot of heat because it operates in class-A. Its current is probably too high for the contacts on a solderless breadboard, solder the connections together on a pcb instead.
« Reply #3 on: March 16, 2018, 03:58:40 pm »
Leo
Thank you Leo, and that 8 ohm resistor is supposed to represent the speaker. That was my reading. I tried asking the author but got no response
Offline Zero999
  • 0999
« Reply #4 on: March 16, 2018, 11:22:49 pm »
The trouble is with the way it's biased, the collector voltage will be heavily dependant on the Hfe. My guess is a couple of volts, at most, so far too low.
Reduce the resistor values and add a capacitor to keep the base bias constant, irrespective of the signal. See attached. For convenience, I just used a constant current source, rather than the LM350 circuit.
The circuit is fine for very low output levels, but will distort horribly, at higher amplitudes. Being class A it's also very inefficient and is a poor choice for driving a speaker. I've used a similar design, in a mic. pre-amp and it was fine, but wouldn't consider using it as a power amplifier!
Removing C2 will make it more linear, at the expense of gain. Another option is to AC couple a resistor from Q2's collector, to Q1's base, which will reduce the gain and the distortion, but not as much as removing C2.
« Last Edit: March 16, 2018, 11:37:00 pm by Hero999 »
