HI,
I designed a frequency counter using CPLD that counts upto 50MHZ , but I found problem in designing the analog front end. I know what front end analog circuit does. I go through various frequency counter schematics they all used differential receiver at the front end with ECL. I know it is faster due to non saturation of transistor. most of the theory said that the differential receiver was used for gain and Schmitt trigger. can I used just opamp amplifier and a Schmitt trigger in the front end . Is it work.............
