Hey guys, I'm kind of new to external EEPROM programming on IC's, and the one I'm using needs an external EEPROM program voltage of 14V.
In the datasheet, it says to enable this 14V, wait 16ms, then disable it again. My question is, does this mean it can _only_ be on for 16ms, or would plugging it in, then "quickly" unplugging it by hand be sufficient?
Cheers,
Dan
