Author Topic: PCB one size fits all  (Read 611 times)
Offline gogomanTopic starter
« on: March 08, 2018, 02:37:11 pm »
Hi  I need advice for a PCB layout. Depending on the application the PCB will be trimmed to fit.
The signal and power traces will be cut as pcb is shorten.
The PCB is 4 layer (signal, ground, power signal).
thanks
« Last Edit: March 09, 2018, 02:14:41 pm by gogoman »
