317s are cheap and cheerful, but they have high minimum iq requirement.
What!?
Do we understand iq the same way?
LM317 has iq about 50uA (hope I remember well as I was measuring it in 90s) and it not varies with load current what you can take in count counting feedback resistors.
What 317 needs is high minimum load current of about 5mA that in typical 317 application is ensured by using small resistor values in feedback divider but you are not forced to use that way. I was using LM317 with even 2k7 resistor from output to feedback pin (about 0.45mA/0.5mA (50uA difference) in feedback resistors). Of course you loose some precision.
This approach is possible in two situations:
1. when your load in all conditions consume 5mA or more, what fulfills LM317 needs, or
2. when you don't care if LM317 regulates or not - if you use it to distribute power between two regulators you don't care how it is distributed until the current is little higher.
