Electronics => Projects, Designs, and Technical Stuff => Topic started by: grifftech on August 17, 2016, 10:23:04 pm
Title: front pannel design
Post by: grifftech on August 17, 2016, 10:23:04 pm
I am adding a volt meter to a project and designed this frame  for it: (https://1.bp.blogspot.com/-7iwLO3Mtnlc/V7ThoLoQAnI/AAAAAAAABqw/2MrBDThjhFU6ClI0lXp4mTmeGLUhF-75gCLcB/s320/volt%2Bpanel.jpg) The volt meter is from banggood:http://www.banggood.com/0_28-Inch-2_5V-30V-Mini-Digital-Voltmeter-p-974258.html (http://www.banggood.com/0_28-Inch-2_5V-30V-Mini-Digital-Voltmeter-p-974258.html) ( I got the red one.) It is still on its way from china. Feel free to modify my design. I will post more when I get the parts.
Title: Re: front pannel design
Post by: Blastcap on August 18, 2016, 07:46:38 am
With the info i can't really see what to change and why.
But how bout some more info, like panel material and thickness, are you planing to make the front panel before or after you get the meter, do you have a precise cutout dimension?
What tools do you have at your disposal, and what are the small 3V - 6V in the bottom right corner?
Post by: grifftech on August 19, 2016, 01:07:46 am
plywood, 1/4 inch, after, use the link, drill and utility knife, two different voltage rails
