Author Topic: Molex Picoflex connectors.  (Read 5575 times)
Offline ISmellBurningTopic starter
« on: July 29, 2013, 03:09:42 pm »
'lo all.
Anyone familiar with these IDC connectors?  The tool to crimp these is priced around at £800  :-DD.  My question is, has anyone used this with a more usual set of IDC crimp tools?    Can't believe the price of those crimps!  I'd love to use these connectors in my project but there's no way I'd pay £800+ for 'em!
Cheers!
p.s
Connector  - http://uk.rs-online.com/web/p/idc-connectors/6702327/
Crimp tool  - http://uk.rs-online.com/web/p/cable-crimpers/5428093/
« Last Edit: July 29, 2013, 03:13:41 pm by ISmellBurning »
Offline Short Circuit
    • White Bream electronics R&D
Re: Molex Picoflex connectors.
« Reply #1 on: July 29, 2013, 03:43:50 pm »
Sacrifice a receptable to provide mechanical support for the pins, then you can use a regular IDC crimper like these;
http://www.ebay.com/itm/IDC-Flat-Ribbon-Cable-Crimper-Crimping-Tool-Ship-From-USA-/251311312776?pt=LH_DefaultDomain_0&hash=item3a83524f88
Used this method alot with the very similar AMP micromatch connectors.
« Reply #2 on: July 29, 2013, 05:05:34 pm »
Hiya, yup those were the exact pair of crimp tools i was thinking about getting.  But i wanted to know if those picoflex connectors will actually fit in those cheaper crimps. If you see what i mean.
Thanks for the suggestion tho, I may well end up having to do that and forget about using picoflex.  :(
Anyone actually tried them before?
Offline Neilm
« Reply #3 on: July 29, 2013, 05:49:06 pm »
I have used these before - I designed them into some equipment at work. I used them as they were small, and self locate and securely clip in. As far as I remember, there were hard to crimp as each contact has to be pushed through individually. I think I started them with a pair of parallel pliers they pressed them in with the tips of snipe nose pliers.
If this is just for a hobby project - I wouldn't bother using it. I only used it on the project I was on as I was space constrained that that was the only one that would fit.
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
« Reply #4 on: July 29, 2013, 06:06:20 pm »
Smallest jaw height of the crimper that I have is 7.1mm. Don't know if that would be small enough.
However, the yellow block is easily removed and replaced with something thicker.
« Reply #5 on: July 29, 2013, 06:40:43 pm »
Neil
Ah... that's exactly what i needed to hear! Thanks Neil...  I'll look for a different type!
Thanks again, you've saved me both cash and time.
PS.  And thanks to the other that replied, its appreciated guys!
