he claims he is drawing power from the 1 volt so turning off the transistor the collector voltage will collapse very quickly.
there is one caveat though .. we are reverse polarizing the b-e junction ( fpga output high pulls base above emitter... ) you can do that but no more than 4 to 5 volt. after that you get irrepairable beta degradation. that stuff is destructive for transistors.
Yes, as you said, it shuld be safe up to about 5V, unless the transistor is some
fast one, if I remember correctly, some fast parts claim 3V abs. maximum for reverse b-e.
if you get that thing to avalanche you will inject 'hot carriers' into the base. What happens is essentially charge gets trapped in the depletion layer. this charge makes the transistor 'leak'. the net effect is that its beta (hfe) goes down. this process is (almost) irreversable. You can recover partially by releaseing the 'hot carriers' by baking the transistors at high temperatures ( 200 to 300 degrees) for 24 or more hours. this lets the trapped charge leak away restoring the transistors operation.
This makes me curious, repairing old equipment, sometimes I've found dead transistors
with very low beta. The two junctions test good with the diode tester, but the beta
is too low. This could be the reason of what I found into the fluke 343a.
It's output is driven by 4 2N3739, the previous owner made a mistake trying to repair it,
messing the main voltage selector and the transistors were probably exposed to excessive
voltages.
The result is one open, one still working, and two without gain. I wonder if they could be recovered... just for fun.
Fabio.
